Description
The Kite Chest Harness in combination with a threaded Link Sling have been designed to be used with any of the SAR sit harness range for added comfort and protection. The Kite can be utilised for climbing, mountaineering, rescue, intervention and technical access.
The harness has front loops for use with a Link Sling to keep the user in an upright sitting position when connected to the sit harness to give a full body harness format conforming to EN361.
The Kite can be used for connecting a chest ascender by using the 25mm front strap threaded through the top hole of the ascender and the bottom of the ascender connected to the sit harness. The chest ascender can be fitted over the Link Sling and a karabiner in the chest loops giving the ability to be used in an instant.
The Kite & Kite QC Chest Harness MUST NOT be used on its own.
Specifications:
- Fully adjustable
- Wrap around cross fitting
- Interlocking shoulder buckle system
- High quality polyester webbing
- Supplied with Link Sling
- Quick Clip buckle front harness connection – Kite QC only
Weight:
- Kite – 350g
- Kite QC – 445g
Product Codes:
Kite: H0010
NSN: 4240-99-229-5357
Kite QC: H0010QC
