Description
The Work Positioning Belt is manufactured using a 45mm high grade polyester webbing. It is fitted with two side mounted alloy ‘D’ ring attachment points. These alloy ‘D’ rings are able to be secured back with velcro retaining straps for when they are not in use.
The belt also has the benefit of a 6mm padded foam, this gives back-support and improved comfort for the user. It is fitted with a Quick Clip buckle for easy fitting and removal. The back of the belt incorporates a rear restraint loop which can be used for connecting a restraint lanyard. Bespoke versions of this belt can be made to order.
Specifications:
- Rated to 150kg
- Size: 30” to 38”
- Weight: 440g
Product Codes:
Work Positioning Belt: RS036BLK
